show msrp talkers
show msrp talkers {egress | ingress | ingress-and-egress} {port port_num}{source-mac-addr source_mac_addr | stream-id stream_id}
Description
Shows MSRP talker attributes.
Syntax Description
msrp Multiple Stream Registration Protocol.
talkers Talker attributes.
egress Display egress talkers only (default).
ingress Display ingress talkers only.
port Filter based on ingress port number of the stream.
source-mac-addr Filter based on source MAC address of a data stream.
stream-id Filter based on stream ID of a data stream.
Default
N/A.
Usage Guidelines
Use this command to shows MSRP talker attributes. The output can be filtered based on the stream id, source MAC, or port number on which the talker is registered.
# show msrp talkers
      Stream Id            Port  Dec     Dir     State         Failure Code
                                                App  Reg
00:50:c2:4e:d3:2d:00:00     19  Adv   Egress   QA   MT   -
                            21  Fail  Egress   QA   MT   AVB incapbl port(8)
00:50:c2:4e:d3:2d:00:01     19  Adv   Egress   QA   MT   -
App      : Applicant State,                Dec   : MSRP Declaration Types,
Dir      : Direction of MSRP attribute,    Reg   : Registrar State
MSRP Declaration Types:
   Adv   : Talker Advertise,               Fail  : Talker Fail
Applicant States:
   AA    : Anxious active,                 AN    : Anxious new,
   AO    : Anxious observer,               AP    : Anxious passive,
   LA    : Leaving active,                 LO    : Leaving observer,
   QA    : Quiet active,                   QO    : Quiet observer,
   QP    : Quiet passive,                  VN    : Very anxious new,
   VO    : Very anxious observer,          VP    : Very anxious passive
Registrar States:
   IN    : In - Registered,                LV    : Leaving - Timing out,
   MT    : Empty - Not Registered
This command was first available in ExtremeXOS 15.3.
Platform Availability
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
